Fried bulb in cluster on W202? How to replace it
noogieman
EU
I Loewe Old Skool AMG
So it finally happened, one of the bulbs in lower left side corner in instrument cluster fried causing my outer temp not to illuminate.
This is on a LHD car.
What is the easiest way to replace this bulb?
I have the MB tool hooks to insert in the gaps between dashboard and cluster?
If I take this route dashboard could get damaged with scuffs or scratches because it's very tight, seem to be risky business?
# Remove steering column under tray, inserting my both hands back of the cluster and carefully trying to push it out?
# Or trying to find the fried bulb by inserting my hand back of the cluster bottom corner fiddling in the dark?
Seem like a difficult task?
I asked dealership, I was told this was a two hour job, disconnecting battery, removing steering wheel etc etc.
Very pricey job from dealership replacing bulb.
One bulb cost approx £6 quid.
Job approx £350 to 400 quid?
