Fitted the new Wahler thermostat this morning. Easiest job I've ever done on a car I think. It took longer to collect the tools gloves and cleaning rags than doing the job. Must have taken all of 10 minutes in total. Only lost about an egg cup full of coolant too. Certainly no need to drain the radiator to do the job. Just pull out the old thermostat and housing and push in a small cloth wrapped in plastic to stop the coolant leaking from the engine block.
Took the car for a run, and the temperature gauge went up to 85c within a mile. Blasting out hot air and the mpg visibly improved over just a 5 mile run.
Well worth doing myself as a local indy wanted £99 per hr diagnostics plus fitting charges.
Old thermostat
New thermostat with supplied O-Rings fitted.
New thermostat comes in a Borg Warner box with a small Wahler logo.
Wahler clearly stamped on the thermostat.
I returned the main dealer one that cost me over £50 and got an OEM one from Lithuania for £23, delivered in a week.
For anyone thinking of changing the thermostat in an M271 engine, the faulty one I removed was a Wahler with Part# A271 203 03 75
Part since updated with # A271 203 05 75
Borg Warner Part # 3457.90D
E2930019509
![20220917_140320[1].jpg 20220917_140320[1].jpg](https://forums.mbclub.co.uk/data/attachments/105/105653-af746439fc296238940ffed5f1e161cd.jpg?hash=r3RkOfwpYj)
