Fuel injector question?
mr tibbs
Desborough, Northants
S211 E320 Estate
Hi all. Our 211 E320 55 plate with 200+K miles has recently started to misbehave when starting from cold. We wait for the glow plug light to go out and then turn the key, it cranks over a few times (it used to start on the 3rd or 4th crank) and then seems to run on less than the 6 cylinders then pick up and runs perfectly smoothly and always starts perfectly when hot.
I just spoke to our local garage and they are recommending taking out the injectors and sending them away for testing (at about £25-30 each) and they suspect that at 200K miles they will need replacing.
My questions are 1) does this sound a reasonable diagnosis and 2) can anyone suggest a place to buy replacement injectors at less than the estimated £300 each please?
We have spent a small fortune on the car this year and could do without spending a truck load more.
Thanks in advance.
Keith
You have PM
Hey no worries
The Oe Bosch number is
0986435136
The Service exchange Bosch number should be
0986435135
The above assuming 211 e320 cdi om648 I6 engine 2003-
No mate, it has the V6 OM 642 engine, 211 E320 cdi estate 2005 (55)
Thanks for the info though...
Keith
Are you sure? Mine is 2005 and has the 648. :)
om 642 v6
Bosch Oe: 0445115064
Exchange : 0986435355 Aprox £160 each plus vat
Hi, yes definitely a V6, we had the I6 previously in a 210.
Keith
