Fuel relay fault
Gizmops
Spain
1992 A124 300 CE 24v
Hi all, i have a 1992 A124 300 ce 24 v. A year ago it just died on motorway. Tried various suggestions, no solution. Today i checked the 2 fuel pumps and both dead, no 12v power feed. Have been told there is a relay, where is it please
Its behind the battery-under a large flexible black plastic cover
Thanks, Grober , i have looked there, forgot to say mine is lhd, the big black cover is on the right, do you know which relays, lots of them there and all thd fuses.
Hi, attached are 2 photos. Lhd side where battery is and rhs fuses and 3 relays. 2 large ones and i small one. Hope this helps.
Cannot see the photos Grober will reply soon,but if you can see the relays the fuel pump one should have 003 545 2405 on the top if that helps.
003 545 2405 is not the relay for a 300-24. The relay is in the MAS box, the one on the left:
Usually very reliable. If you need to replace it, make sure you search the EPC and get the correct part numbers as they vary according to aircon, gearbox etc.
Twiddle the knob on top anti-clockwise to release.
Good luck.
RayH
