Obviously it makes sense that you have alignment / geometry checked before changing tyres so the new ones track right and the car drives as it should.
However, is it necessary for a car to have all new tyres for a full geometry check to be accurate?
Or is it the case a geometry check and correct can be done on older tyres (I'm wondering if the difference in tread depth might alter the readings)?
I've had a geometry check and correct done on my E55K previously and once done, the worn out fronts started getting really screwed up as the geometry was quite "out" when I first had it done. However it didn't matter because I went on to change them and the new tyres were fine for ages.
It's never been pointed out before to me prior to a geometry check and correct hence the doubt.
