Hi All
Hope for some help from some people with more knowledge of Mercedes than me.
After 7 years of 14 hour shifts i finally saved enough to buy a 2018 GLA 250 2.0 Petrol, Fell in love with the car as soon as i saw it but have been a bit concerned about a possible cooling issue.
When changing the oil i noticed a small amount of coffee coloured liquid on the oil cap, panic set in but i have since read that this can be normal in cold weather?, the wife has also been saying that even on a very short run the radiator fans are on for most of the time, it also reaches operating temp in a very short time.
I checked coolant level when cold and it was about 1cm above the white T but when hot it is almost at the filler neck, i can also see some stains from coolant under the expansion tank but it does not appear to have a leak.
It smokes a little bit of white smoke from cold start up but nothing that would seem out of place and goes away when warm, the temp gauge has never gone above the 3/4 mark in the 2 months iv'e owned it. The coolant colour is not as pink as the new coolant i purchased but also not that discoloured.
The car has only done 25000 miles and has full service history so i cant believe it can be a head gasket problem but because i am not used to Mercedes and there quirks i wanted to ask for your guys knowledge, I have put every penny i own into the car and will be devestated if there is a problem but also don't want to bury my head in the sand about a potential issue.
Many thanks for anyone that can help,
Bob
Bob
