Hi
My 2017 GLC250d has been getting harder and harder to start, tried all sorts including new injectors and no improvement. 3 hrs at main dealer workshop last week and they have no idea. Anyway I have finally tracked it down to extremely low compression on cylinders 1 & 3 showing under 9bar, cylinder 2 showing 15bar and cylinder 4 not even registering compression. All well below the minimum 22bar needed. Compressions tested manually the old fashioned way not electronically with Star (dealer said star didn’t pick it up)
We even used 2 different compression gauges as we didn’t the believe the results, but both were consistent.
When it cranks over it attempts to fire, it gathers and gathers and eventually it will start (very much like an old diesel with only 1 glow plug working). As soon as it does start (can be several attempts of cranking timeout) it runs as smooth as anything, no misfire, no juddering and no smoke, it drives absolutely fine and pulls like a train. (Although it will sometimes stall when pulling up if still cold) Even if you drive it hard and keep it revving it does not smoke one bit, so I’m sure it can’t be piston rings or warn bores.
The starting is the same wether hot or cold but is worse when cold.
We discovered that on cranking only cylinder 2 is firing, hence the gathering behaviour of the other cylinders. I believe that cylinder 2 is the only cylinder with enough compression to ignite.
Car has 135k miles with full history, has always had genuine Merc oil and parts. It has not happened quickly but got progressively worse over the last 3 months.
Now I don’t understand how cylinder 4 can be zero on compression when cranking but without a misfire when running. (All cylinders are well below what they should be)
So we, did a leak down test (just on cylinder 4 as it’s the worst) and it would appear to be leaking out the air intake so clearly on the inlet side. It can’t be a just a burnt valve as it would be obvious when running, plus that would mean all inlet valves are burnt as all compressions are so bad.
My conclusion is that something is holding the inlet valves open (to varying degrees across the cylinders) but only during cranking, once it fires up it runs absolutely fine, and drives fine as well, has plenty of power and no smoke.
I thought maybe timing chain had perhaps stretched or jumped and put the cam timing out but it runs perfectly quietly as soon as it has fired up, plus I think a jumped tooth on timing chain it wouldn’t run at all.
Anybody experienced anything similar or have any idea on cause? (My last Merc with the 651 engine did 250k miles and was still going strong when I sold it)
Any help appreciated
