I can spot the bumper / body mismatch on most cars in most lights and it's not just the angle mismatch of panels so I presume this must be something to do with modern paints.
I wonder if water-based makes any difference but then cars older than that have it.
Yeah could be. I suppose that is in and out a lot more.
The steering wheel looks a little shiny but could be a trick of the light.
I imagine you could service a car, run it for 20k > 30k, clock it, service it and MOT it and get away with a huge mileage.
An S320CDI would be a perfect candidate for clocking I would have thought.
Hopefully I am wrong though and I'm not sure what else you could do to check other than look for wear.
S Class are heavy on suspension components regardless of mileage because they are heavy so not necessarily a sign.
Hopefully the service history means the owners have been conscientious enough to keep it so and are unlikely to be the types to do that.
Saying that, these cars are capable of huge mileage if looked after so perhaps not such an issue anyway.
When I think back to my 211 55, I am a heavy get and all I had was a slightly creased bolster which was there when I bought it.
I did 18 miles to work and same back for probably 4 years and then 13 miles each way subsequently so not huge trips most of the time.
I don't wear jeans much so maybe this has a bearing.
This is my car when I bought it and when I sold it (5.5 years and 50k miles):
The seat wear might be indicative of lots of short trips, consistent with the (relatively) low mileage?
There again it is 12 years old..
