Hi guys I currently have a silverline buffer but would like a smaller one as the silverline is a bit too big and suggestions? What have you guys got/use approx 100 quid budget thanks
Das 6 pro
This is what you want the das is a orbit polisher
So easer to work with if you select the right pads and polish you'll achieve the same results as using a rotary.. Get the pro though as its got a longer cable and a higher powered motor..
