Heavy vibration when braking
Funkyboy
E class
Hi all, 14 plate E250 heavy vibration through floor of car and brake pedal but not through steering wheel. Front discs and pads are 4 mths old rear 14 mths. If it was front suspension or discs wouldn't the steering wheel shake as well?
Usually, yes. It sounds like a rear problem to me. A friendly MoT tester might put the car through a brake roller test for you to try to pinpoint the issue
You can try jacking the car up and see if the wheels spin freely, if so your discs are likely fine
