itsmattyjayy
Hello everybody! I'm new to the forum, as you may be able to see? I recently bought my first ever Mercedes, I got a good deal on it because the rear right door wasn't able to be opened from the outside, the handle just pops out when you pull it. No worries, it still locked as normal and was openable? from the inside so I made do.
A very confident friend of mine said if I switched the switch on the inner of the door - which I now know is the child lock switch - the problem would be solved. Well, you guessed it, I now can't open the door from the inside OR the outside.
I took it to a local garage and he said he has no idea how to fix it, without breaking the door. I'm wandering whether I can somehow get a coat hanger in there and 'flick' the child lock back up, allowing access from the inside after which I can then get the door handle repaired.
Any advice would be greatly appreciated. If anyone is a competent mechanic or bodywork specialist? I'm in the Bolton/Manchester regions and would be happy to pay for the privilege of opening my door once again if anyone knows a fix or has done it themselves or knows of someone (or a garage) that can fix such an issue reasonably.
Thanks!
Matt
Thanks!
Matt
