help washer pump not working
Yaza01
Birmingham
Clc 200
hi all my 2009 clc c200 mot coming up and my washer pump is not working
when i push in the stalk the wipers wipe but no washer pump/no noise
i have put in a new washer pump
thanks
I think it's a power connection issue. Cause when you push the stalk, there where no sound. You might wanna look into it.
If they are the same design as my e55 you push the stalk then hold it in and it clicks again then sprays, I thought mine was dead but I wasn't doing it right.... Worth a try mate...!
Lee
Stalk,fuse, wiring, connector...that's all that's left seeing you have changed the pump.
As Marty said, fuse , its the first thing you do in future ..Make sure the fuse is ok befire spending on new parts .
