flintx
Hi all, can anyone help with 9062 communication fault with component battery sensor. The only thing that doesn't work is the auto hold (when brake pedal pressed twice say at red light). Has anyone came across this issue and managed to fix it? I have emailed mercedes for a battery sensor but it's on back order and around £170 with unknown lead time. Don't really want to spend that if there a simple solution to this problem which you gurus already solved in the past? Many thanks
