Hi does anyone know how to activate the door mirror lights on R172 slk. I understand this is code is 876. Can you complete this using icar device.
Johnyda
Harrogate
Slk R172 2012 AMG BLUEMOTION CDI
No that doesn't work,but I will check the Fuse. When I am able to identify the correct fuse. Many thanks for your input.
If they aren’t working, I think you will need the harness from the lights to the door controller, and then coded in.
Iirc, they are fitted but not activated.
A bit like the transparent roof. This was a cost option, but all of them had it (later models) however Mercedes deliberately bonded an opaque cover to the glass so you couldn’t just remove the headlining.
