The om603 diesel pump should be first on your list.
I've got a holset h1e ready for when I do mine.![]()
No real reason to change the pump as the 606 pump has larger elements and the ECU can be mapped for the cost of an EEPROM.
"Bones" has done his own.
Anyone has a spare Turbo that is picking up dust and will not be used?
I am looking for an Holset HX35 or a Garett T3/ T4 or bigger ( for both)...
Thank you.
Olivier
I had a daf cf85 truck in for repair today, alot of those run a hx35 with a t4 mounting flange. Perhaps one of the truck breakers yards could help you?
The manifold ideally needs an elbow to allow the turbo to sit higher and match the exhaust. If you have a look on superturbodiesel you'll notice there all positioned high towards the front of the engine. Someone on STD was selling a HX35 with different exhaust housings in N.Ireland.
Couldn't see it on STD?
you wouldn't have a link you could send out to me in case its a different one and its still available?
Cheers![]()
Why not fit two standard turbo's. That should be good for about 500 Bhp but spool up quicker than a single large one.
I just checked, it's the same guy and it's all sold.
Are you keeping the 6mm elements?
