How do you remove.....
Quigs
the carbon looking trims on the sides of the doors of a S210. Mine are looking discoloured and corrosion starting to show in areas.
Also, how much can I expect to pay for a set?
If you pull the door seals away fro the edge of the door, then you'll find they are secured in place by a couple of small screws top and bottom.
Remove them and then lift and push towards the glass and the over side will unclip.
Quite simples then? Any idea how much a set of these are?
