I changed the original style wiper blade (with pressure arms at various points) because half of it often stuck to the screen when near the parking position if it wasn't wet enough. On the return or when it was turned on again it made an almighty crack as it straightened itself. Not good for an impending MOT.
I got a Bosch blade, the correct part for a 1995 C220, made in a single piece. Its frame is a lot wider than the original, just hitting the lower left window trim when operating and parking and sweeping to 25mm above the right lower trim...so I want to adjust the sweep.
This makes me regret changing the blade style and also I didn't appreciate that the new one would not fit between the lugs on the blade operating arm that used to hold the original style straight.
However it looks like the sweep never was balanced so is this small amount of adjustment possible?
