Interpreting VIN Checks
Stocho
I tried one of the sites for VIN checks (Checking VIN for Mercedes-Benz WDB2112262A720603 | CARInfo) to check prospective purchase E320CDI Avantgarde 2004 Estate.
From what I could read I understand it has heated windscreen jets, dimmable mirrors, parametric steering,Bi-Xenons, larger diesel tank. Are there any other desirable features?
Also should i Be concerned by the following text?
" THE ORDERED RIGHT-HAND DRIVE ENGINE IS NOT AVAILABLE, PLEASE USE THE LEFT-HAND DRIVE E THE ORDERED RIGHT-HAND DRIVE ENGINE IS NOT AVAILABLE, PLEASE USE THE LEFT-HAND DRIVE ENGINE A 648 010 05 00 AND TAKE THE ENGINE CABLE HARNESS FROM THE OLD ENGINE OR ORDER THIS PART NEW ACCORDING TO EPC"
Anything else worth noting from it?
The Actual VIN Check Results:
Delivery date 2004-11-12
PAINT1 693U
Interior color 835A
Engine 648961 30 106447
Variant
A 648 010 06 00
Number for spare parts
64896130
Text
DER BESTELLTE RECHTSLENKERMOTOR IST NICHT LIEFERBAR, BITTE DEN LINKSLENKER-MOTOR A 648 010 05 00 VERWENDEN UND DEN MOTORLEITUNGSSATZ VOM ALTMOTOR UEBERNEHMEN ODER LAUT EPC NEU BESTELLEN THE ORDERED RIGHT-HAND DRIVE ENGINE IS NOT AVAILABLE, PLEASE USE THE LEFT-HAND DRIVE ENGINE A 648 010 05 00 AND TAKE THE ENGINE CABLE HARNESS FROM THE OLD ENGINE OR ORDER THIS PART NEW ACCORDING TO EPC
Text
Front axle 2 AL231140824611
Gearbox 722626 05 756834
Class 1
Infotable on engine A01000648 06
Audio serial number AL231140824611
Code Value
205B OWNERS MANUAL AND SERVICE RECORD - ENGLISH
213 SPEED-SENSITIVE POWER STEERING/VARIO STEERING
221B SIGN COOLANT/REFUELING - ENGLISH
249 INSIDE AND OUTSIDE MIRROR AUTOMATIC DIMMING
250B MOBILO LIFE/EUROPE SERVICE PACKAGE
280 LEATHER STEERING WHEEL AND LEATHER GEAR SHIFT KNOB
283B AIRBAGLABLE - ENGLISH
287 THROUGH-LOADING FEATURE
423 5-SPEED AUTOMATIC TRANSMISSION
461 INSTRUMENT WITH MILES IND. AND ENGLISH LEGEND
500 OUTSIDE REAR VIEW MIRROR LH AND RH FOLDING
537L GREAT BRITAIN AND NORTHERN IRELAND
543 SUN VISOR WITH MAKE-UP MIRROR L. AND R., BE-
551 ANTI-THEFT/ANTI-BREAK-IN WARNING SYSTEM
580 AIR CONDITIONER
5XXL EUROPE
600 HEADLAMPS - CLEANING EQUIPMENT
618 BI-XENON HEADLAMPS FOR LEFT-HAND TRAFFIC
666 PRODUCT PROT.F.TRANSPORT VEH. W/O TIE-DOWN HOOKS
690 EMERGENCY SPARE TIRE (MINI SPARE)
693U TRAVERTINE BEIGE - METALLIC PAINT
805 YEAR OF MODIFICATION
830A AMARETTA/LEATHER/NAPPA/SEMI-ANILINE
835A AMARETTA/LEATHER/NAPPA/SEMI-ANILINE - BEIGE
875 HEATED SCREEN WASH SYSTEM
882 INTERIOR SAFEGUARD
910 DYNAMO WITH HIGHER CAPACITY (FFO)
915 FUEL TANK WITH LARGER CAPACITY
954 EQUIPMENT PACKAGE FOR AVANTGARDE VEHICLES
984 COC DOC., DELETION OF VEHICLE REGISTRATION DOC.
989 IDENTIFICATION LABEL UNDER WINDSHIELD
M002 ENGINES WITH EXH.TURBOCHARGER WITH INTERCOOLER
M32 CAPACITY 3,2 LITER
M648 R6-DIESEL ENGINE OM648
U15 2ND CARGO AREA W/ COMPART. UNDER MAIN FLOOR PANEL
U16 STOWAGE TANK BEHIND REAR SEAT BACKREST
System information
Code Value
Data language en
DB storage version 1.0
Data display version 2.1
Manufacturer's data version DW 11/2014 Delta 3 from 2014-12-10
help
Well i dont think its anything to worry about.Looks like the engine that is to be fitted had run out .So makers fitted the other hand type , and used the existing wireing lay out. You could take a print out to you Mercedes dealers service depot and ask them for information on why this was done.
The text simply means that if you want to order a new engine, they cannot supply it equipped for right-hand drive - you must order a left-hand drive version (i.e. standard) and then re-fit the existing right-hand harness from your car.
