Evening,
I know we all hate this sort of post, the one with the issue which could be anything, thus I have looked into it as much as I can (without getting ones hands oily).
My E55 has had a strange problem with braking which Deiselman suggested could be (and still could be) braking friction material on the disks. Issue is that I get virbration when mid braking, light or heavy braking is fine. Also when braking at slow speed I can feel a spot where the disks slow the car quicker...... Which then brings me onto problem two which could be related.
The car shakes. Noticeable at 85mph upwards and felt through the seat (thus assume coming from the rear). Can feel a small amount through the wheel, but the seat does shake and gets worse with speeds to 100 plus. It is certainly coming from the floor pan.
All wheels have been balanced. On going through old MOT's it did point out a rear brake imbalance. On inspection it looks like the offside rear wishbone area is quite new.
Could this all point to an offside hub imbalance which is effecting braking and causing the vibration. How likely is this ?
Either way it's going to involve going to W124 or nearer specialist to get sorted. Just want to check I am thinking along the right lines.
Cheers Ian
P.S. I use AutoGlym on it if that helps
