The problem with jump starting is "load dump". What happens is you get the car started (so far so good) now the alternator (which can push out 200A or so) maxes out charging the flat battery. Still OK. Now you disconnect the first battery/car and this is where the problem occurs. As you disconnect the battery the load being charged reduces but the alternator is running flat out. The result is a big voltage spike for a moment until everything settles. That spike can destroy car ECU's, pretty much any ECU on the car.
If you jump start from a running second car that car sees a load dump when the jump leads are disconnected so it can be damaged too!
There are various ways to try to minimise the spike - like turning on the rear demist - before disconnecting the jump leads, or letting both vehicles run for a good while before disconnecting the leads. However in a car with a big battery, powerful alternator and lots of ECUs jump starting is a risky business.
https://alzaabiautocare.com/blogs/how-to-jump-start-a-car/
