I had the same problem with my 1989 Audi 90 - actually KE-Jetronic, but similar in design. By following the test Bosch test instructions, I was able to bypass the various cut-off features & run the injectors into 5 clear plastic bottles to check the spray pattern, then dry each injector, place brown paper underneath & check for leakage with the metering plate in the closed position. This showed that some of the injectors were leaking petrol & emptying the accumulator over a period of a few minutes.
The other failure were the 'O' rings that seal the injectors into the head. Cheap to replace, but a real swine to do.
In 250k miles I had to replace the injectors & seals twice.
Ian.
