Keyless go
Tan
Woodford Green
W140 S-Class, Porsche Cayenne and Porsche Boxster
Hi
I am having a problem with the button that you press in the door handle to lock the doors. All are working except for the drivers door button.
I was working up until today, can the rubber bit be easily removed to see if the switch beind it is working?
Tan
Returned to the car today and they are all is working again :-)
Sounds like it may have been the cold weather. I hope so because mine has stopped working on the passengers side!
I noticed the rubber split on mine.. it worked for a few months until the water got inbehind the rubber and stopped the switch from working...
Keep meaning to get a replacement... unfortunately you cannot buy just the rubber and replace that part.. you have to change the door handle
