Kick down
cool20
1989 E230
Hi , i read that kickdown switch is below the accelerator. i want to know how do u kick down and what is the function of the switch ?? thanks
Press your pedal to the metal as quickly and as far as you can and see what happens:D:D
Just put your foot to the floor & you'll find out!
beaten to it!
Still have a switch??????
I thought it was all ECU controlled these days??
It may be ECU controlled, but unless the ECU has a signal informing it of the desired request, how will it know what is needed.
The signal from the kickdown switch tells the ECU that the required action is needed NOW.
I suppose soon we may well be able to speak the instruction, or just grip the steering wheel tighter, or ........................ the options are endless.
