knocking noise
worrall1959
2000 CL500
Guys can anyone please help me or advise me of a problem, I have a 2000 CL 500 2 door coupe, the bottom ball joints have been replaced as have the track rod ends however i am still getting a knocking noise when driving over bumps in the road !! i have looked at the different MB forums and could it be the suspension drop links !! if so does anyone know where i can order them from please.
Regards,
Phil
It could well be the anti roll bar drop links. Eurocarparts stock them and offer a Forum discount.
Hi Stratman, thanks for your prompt reply, called into my local branch in Bamber bridge in Chorley and they could not find them on the system !!!! any idea what the part no's are please.
Could be any number of things . ARB bushes , shock absorbers ......
Have you tried 'bouncing' the car when stopped to see if you can provoke the noise ?
Can you localise the noise when it happens ?
It will not be the drop links on a 215 cl. Quite possibly the the ball joint pressed into the lower arm that the drop link connects to, but not the link itself
Hi Derek, have tried bouncing the car no noise, have had the bottom ball joints and track rod ends replaced !!!
