Left side lights on A180 Diezel 2009(W169) do not work
VladimirLV
UK
A180 Diezel 2009
Hi. I have an issue with the lights on A180 2009 diesel with the lights on the left side. Both, the front and rear running lights stop working. I thought it would be the issue with fuses, as the headlight bulb is fine, but there are no fuses for lights. What could be the problem? May it be an issue with one of the relays that are with SAM? Don't want to start buying expensive stuff before I know what to buy. Can anyone point me in the right direction?
Get the car booked into a Mercedes specialist who should have the necessary diagnostic equipment to pinpoint the problem.
If you post your location someone can possibly recommend somewhere.
Yep, that would be the easiest solution... unfortunately I cannot afford even for them to look at my car, let alone diagnose it. :(
Welcome.
An odd question - is the indicator stalk in the centre position?
Welcome.
Yes
