lights...no lights !!!!!!
sean3513
grange-over-sands
e320 cdi
hello
i have an e320 cdi 2002 w210
the nearside side light and tail light keep going out ( same circuit)
the fuse is ok.....but, if you take the fuse out and put it back in they work, so, i presume it is a relay sticking.
they will work 3-4 times then they go off again
so....my question is where are the relays located on a w210 saloon ???
and which one is for the nearside side light/tail light ??
note to self.....must get a haynes (or similar) handbook !!!!!
thanks a lot
sean
Sean
Try a new fuse before you start looking at relays.
Fuses can go intermittent.
Check the back of the rear light cluster, they are a common failure on the W210.
thanks ted and edz
i will go have a tinker..........great advice
cheers
sean
