Mloclam
My C220 seems to be stuck (most of the time) in Limp Home Mode. Symptoms: it won't kick down and won't rev beyond approx. 3000 rpm.
Sometimes it starts this way. Sometimes it finishes this way. Sometimes it changes from whatever mode it started in to the other mode.
It has been suggested a probably cause is a faulty MAF sensor or some split pipe. A google search found an article that stated a faulty MAF sensor could be diagnosed if a running engine continues to run after the MAF sensor is disconnected. This advice was generic, not explicitly aimed at MB engines. Is this sound advice? I just started my car, it wouldn't rev beyond 3000 rpm. I then disconnected the electrical connector to the MAF sensor and the car continued to run and continued to not rev beyond 3000 rpm.
