Ok my set up is as follows:
2010 Mercedes W204 with Comand 4.5 I believe (with the pop up screen).
I have in the glovebox access to plug for an aux cable. The one I have has the Mercedes connector at one end that plugs into a socket in the glovebox and a 3.5mm Jack at the other end.
Ok. If I plug the 3.5mm Jack directly into my phone and select aux via the audio settings in the command screen the sound is great- happy days.
Thing is I would like to use the bluetooth on my phone rather than have a hard wired cable to the phone
To that end I have a Tao tronics bluetooth adaptor with a 3.5mm Jack port. I plug the end of the Mercedes aux cable 3.5mm into the bluetooth adaptor, connect my phone via bluetooth setting to it and play some music from spotify app. You can here the music through the cars speakers but it sounds quiet and distant.
So you may think well it sounds great when plugged directly into phone so the issue must be with the Tao Tronics bluetooth adapter? Well maybe but the very same bluetooth adaptor connected to my old school hi fi system also sounds great with no sound loss.
So I am unsure what to try next.
Does anyone have any ideas?
Can anyone recommend a set up they are currently using that works well?
Thanks and sorry for the long post.
Sent from my SM-G973F using Tapatalk
