Lowering Question
Karl W
West Yorkshire
W124 Estate (Export Spec)
The existing rear springs on a W124 Estate are quite soft and seem to be there to stop the rear sagging when u switch of the engine, has anyone fitted lowering springs to the rear. I'm taking it off the road and I'm fitting bilstine fronts, with Eibach springs. I wasn't sure if the rear end would be too firm using the Eibach springs and was thinking about getting somthing made up to same spec as the MB spring just 35mm lower. I know how to adjust the rear so it sit's correctly and the pump work's properly.
