grober
MB Master
One interesting factor would be that, most if not all? LPG cars have to start from cold on petrol. As we all know MPG figures for such situations are horrendous when running a conventional petrol car.
1. from the obvious one ---if the engine is running and the car is stationary then your miles per gallon is zero
but also
2. during the engine warm up the fuel air ratio is very rich-idle speed is increased-engine and transmission oils are more viscous-auto gear selection to higher gears is delayed. typical figures are of the order of 5-10mpg for the first couple of miles
You would have to factor in this brief high petrol usage into your LPG figures somehow. At present presumably this remains "invisible" while looking at LPG mileage perhaps only to surface when filling up with petrol when it may erroneously become part of the petrol MPG equation?
I'm glad you are enjoying the benefits of running on LPG
--all evidence points to it being a cleaner fuel for emissions but true straight comparisons can be skewed if every factor isn't taken into account.
Putting another way starting from cold on petrol--- fuel consumption is very high for a short time for both LPG and petrol. The danger in comparison is that that abnormally high consumption is being factored into the petrol MPG but not the LPG and worse case scenario in a comparison between fuels on the same car the cold start petrol use for LPG is inadvertently being added to the the consumption figures for running on petrol!
Crucial to any significance would be the period the car has to run on petrol from cold before switching to LPG. So-how long after a cold start on a winter day does it take before you can switch from petrol to LPG for example? Genuine questionas I have no idea.
but also
