evo-number-one
- May 17, 2006
- Location
- Essex
- 1995 W124 E280 Estate / 1992 Lancia Delta Integrale Evoluzione 1 / 1998 FIAT Coupe LE
I have started to experience a problem with my 1994 E280 Estate (approx 90,000 miles) which I hope someone can kindly throw some light upon.
When starting the car from cold, the car settles and ticks over around 650/700rpm - possibly a little low - but still nice and smooth. As the car warms the regeneration valve pulses away. The car pulls and operates perfectly at all speeds.
Once the car is completely warm (reading just over 80 on the temp gauge) the car still pulls as it should, but seems to be not quite as smoothly and when finally slowing to approach a junction or at a standstill, the tick-over is now down in revs as if its about to stall (although it never does). Coinciding with this the regeneration valve no longer pulses. Should this continuously pulse?
When the regeneration valve is not pulsing, the tick-over speed never hunts, it just stays low - almost as if it is going to stall. Initially, I replaced the regeneration valve believing it to be faulty, but the new one has made no difference.
At all times, the car runs on 6 cylinders and is not misfiring (in the past I have experienced those symptoms with coil and harness problems – both of which have been sorted – and the current problems in no way have the feel or restrictions that I experienced with those issues).
Could somebody please describe how the regeneration valve works within the emission/evaporation system and explain to me what series of events cause it to pulse. If the charcoal filter (which although I have a stamped service book, I do not have any invoice/written evidence has been changed) is blocked and no longer efficient would this cause the valve to not operate?
Maybe I am going up the wrong path with the valve/filter - but the car runs perfectly when its pulsing.
If somebody else has experienced the above and cured this issue I would greatly appreciate some guidance as to the cure.
Regards
Bob
Regards
Bob
