AlexM
Hi All,
For some time, my E63 has had an intermittent ticking / tapping noise from the driver's side bank. It tends to sound at it's worst when the engine has been run up to temperature, and then left to stand for a while (say 30 minutes) but it is inconsistent, i.e. it's sometimes there sometimes not. When it is present, it sounds really pretty loud outside of the car and is also audible from the inside.
It becomes less apparent at about 1500rpm, and I think it happens less after the engine has been run hard. Is it likely to be a hydraulic tappet that is blocked or leaking?. Or possibly a rocker arm?.
It sounds exactly like this: - fast forward to 25 secs
I'm going to have to take it in, I think, as it's getting progressively worse. I have done so in the past and it has been returned with no fault found. Can I get a TIPS case raised? Is there a risk of accelerated wear to the camshaft, valve or rocker if there is excessive clearance and one component is smacking into another causing a knocking noise?.
Regards,
Alex
Regards,
Alex
