Bellow
Hardcore MB Enthusiast
Ok back on topic, superchargers and boost plus heat management, I can come back to heat management later, it is important with a roots type blower, in post 9 if modifications are made in the right order, reducing restrictions on both intake tract and exhaust, boost lowers, would it not be ok to fit the larger charger off the -/+ 200 HP 230?
This may achieve the same result as a pulley chane with the original charger to bring boost back to original level, but with the benefit of not pushing the charger out of efficiency and just generating heat, you can over speed a charger, , another topic,![]()
If you ended up having to reduce the speed of a larger blower you may well end up running it at reduced volumetric efficiency (more time for air leakage back past the rotors). If the smaller blower can handle more rpm without any other efficiency loss - I'd work with it.
Supercharging (mechanical or turbo) brings another variable that isn't well acknowledged, namely, a gain in engine volumetric efficiency by lowering the compression ratio. Not immediately obvious as to why, but if you are chasing power above all else (as opposed to a more (fuel) efficient road motor) - worth considering.
