Mansory Ruin the SLS AMG
KillerHERTZ
Administrator
Staff member
Cambs
SL63 AMG
MANSORY Cormeum - super sports car in a striking carbon shell
The MANSORY Cormeum leaves few reminders of the Mercedes SLS AMG. The
sports car manufactured in Affalterbach is only the basis for the latest development of
the automobile manufacturer MANSORY Design & Holding GmbH situated in Brand
near Bayreuth. 660 hp and 90 kg less weight are only two unique selling points of
this exceptional automobile which can only be obtained in a limited edition of 15 cars.
At first glance, the striking design created by its owner and head designer Kourosh
Mansory can easily be discerned. Also the name was picked personally by Kourosh
Mansory: An aria was already the source of his inspiration for the refined Bugatti
Veyron (Vincerò) and this time this is the aria Vide Cor meum.
In order to meet the increased requirements of the sports car when it comes to
light weight and torsional stiffness, Kourosh Mansory's team optimises almost the
entire car body and also exchanges the roof and the wing doors with ultra-light own
developments. A MANSORY front skirt replaces the serial bumper and due to its
well-engineered shape it reduces the uplifting forces at the front axle. Larger air inlets
in connection with a new LED light unit provide the two-seater with an even more
dynamic face.
Additionally, the new front skirt supplies the enlarged cooler with more fresh air
and subsequently propels the air out of the new bonnet. MANSORY also replaces
the front and rear mudguards with broader newly designed light-weight parts.
Therefore, the Cormeum extends by 66 millimetres at the front axle and impressive
84 millimetres at the rear axle. MANSORY side skirts make the two-seater look even
lower and longer and perfectly enhance the rims. The rear has also been significantly
redesigned by the aerodynamic specialists. The apron has been exchanged and a
race diffuser renders additional downforce. A rear spoiler with carbon flaps completes
the aerodynamic overall package.
The extended wheel houses of the MANSORY Cormeum are filled with exclusive
forged wheels with central locking. They measure 9x20 inches with 265/30er tyres
at the front and 11x21 inches with 295/25er tyres at the rear axle. The tyres are
provided by MANSORY's partner Michelin. Due to new springs and dampers, the
Cormeum' s centre of gravity is 20 mm lower than the basic model and therefore
additionally emphasises the exclusive rims.
The core part of the engine modification is the adjustment of high-performance
compressors. Also a sports air filter and a sports exhaust system made of stainless
steel are fitted. These components are adjusted to each other with the help of a
new map for engine electronics. With a top performance of 660 hp / 485 kW and a
maximum torque of 4,850 r.p.m., the MANSORY engine exactly meets the wishes of
its ambitious motor sports clientele. Another performance increase up to 800 hp is
already tested.
As usual, MANSORY turns the interior into a highly functional control centre with
unsurpassable quality and innovative design. Only most exquisite materials are
used for the interior design and therefore render a high level of comfort. The leather
which is processed with masterly skill is very endurable and still extraordinarily soft.
The characteristic natural product with its special grain and the masterly perfected
decorative stitches render an extravagant impression around the newly designed
centre console. Another highlight is the newly developed full size airbag sports
steering wheel. The aluminium pedals and the real carbon applications complete the
luxurious overall impression of the Cormeum.
A senior design technician at the Press Conference
images
Those Mansory people should be taken out behind the barn with a shotgun ...
Too bad - they got there before you could pull the trigger
MANSORY NEED TO BE STOPPED!!!!!! :doh:
I bet the name is what they say to alot of their clients its like "Man sorry but we really effed up you supercar now heres a invoice for 200k for it."
That looks absolutely awful. :crazy:
The main thing I don't like on this is the badge on the nose, apart from that it looks rather hard...!!!
taxi for mansory, it is fowl
with coat in hand - I think the back wing is somewhat OTT but the front is 100 times better than the standard SLS with its horrible nose (which looks like it will be afflicting many new models)
