Gazwould
That's thick stuff compared to the 236.15 fluid .
For information - my manual W124 has transmission losses of 17.9% through a 270cdi box with Millers CRX 75w90NT+ in the box and diff. Accurate MAHA dyno on a warm 22c day to DIN70020.
The old set up was in BHP -
456 Flywheel
369 Wheel
82 Losses
How do you measure flywheel bhp without taking the engine out of the car and putting it on a test stand (engine dyno)??
456 Flywheel
369 Wheel
82 Losses
The dyno uses the freewheel cycle (many other dynos do the same) after the power run to accurately measure the parasitic losses from the ENTIRE transmission to the rollers (from the input shaft to the edge of the tyre).
I think this is still an estimate though, rather than an accurate measure. For one thing the rolling resistance of the tyres will be different between max. power/speed and coasting, due to deformation etc.?
82 BHP losses is 61kW. That's a lot of heat to get rid of. Any idea how that breaks down across the box, diff and wheels. Presumably you would need a cooler on the diff as well as the box.
The dyno can tell exactly how much drag is on it as it slows down so it will give an accurate measure of the losses rather than an estimate.
The point though is that the rolling resistance of the tyres on rundown (just coasting) is not the same as when running at full power (when they deform more). So any estimate of flywheel bhp on the power cycle using that figure will be out. The only thing that can actually be measured is the power being given at the rollers. A hub dyno is more accurate than a rolling road one because the tyres are removed from the equation, but the only way to get an accurate flywheel bhp figure (if this is really needed) is to take the engine out and run it on a test stand.
Question 1.) So, how accurate is this dyno then ?
It is incredibly accurate and consistent.
It is simply the closest thing one is ever going to get without using an Engine Dyno.
So far, we have performed well over 9,000 dyno runs (in words: nine-thousand !) and from
those which we could directly compare against engine dyno data of the exact same engine
we have never been out by more than 1,5% which in any book is a most respectable figure.
(1,5% difference on a 200hp engine for example means 3hp - this would be the absolute difference,
not the difference between runs. The difference between runs is far less)
I think you’re right. It’s an awesome bit of kit untill it breaks!!If I'm not mistaken, the VAG DSG automatic transmission was a development from their racing car box.
