Mercedes 2004 clk500 cab ride height ??
merc85
Harwich
W246 B180
As above,
2004 clk500 ride height does anyone know what the distance should be ground to the centre of front wheel arch? with standard suspension. not avantgarde sports.
Just a update, 670mm is the answer ground to lip of the front wheel arch :)
How about the rear?
(just out of idle interest)
Q. What would the tolerance be, side to side, for differences. Plus/minus.
ie if it was 2mm difference - is that ok?
if it was 20mm- then not ok….. at what point is it an issue?
