Hi guys, i've got yet another problem with my E300 hybrid ( these things are plagued) .
When i start ignition, it stays on the electric drive and instead of switching the engine on, it stays blocked on the hybrid drive until the battery runs out and the car stops.
If i switch on the engine on the SPORT mode , the engine runs fine, but once i put it in Eco ( comfort ) mode , the engine cuts-off and stays locked on electric drive.
I went to my local garage and the only errors that caught my attention ( that might be related ) have been:
P087000 - OIL PRESSURE SENSOR 'C' HAS AN ELECTRICAL FAULT
P126F29 & P126F29 - THE SIGNAL 'HOT START' FROM THE AUTOMATIC ENGINE START/STOP SYSTEM HAS A MALFUNCTION. THE SIGNAL IS INVALID / THERE IS AN IMPLAUSIBLE SIGNAL.
U040100 - IMPLAUSIBLE DATA WERE RECEIVED FROM CONTROL UNIT ' COMBUSTION-ENGINE'
P008709 - THE FUEL PRESSURE IN THE SYSTEM IS TOO LOW
U041600 - IMPLAUSIBLE DATA WERE RECEIVED FROM CONTROL UNIT 'TRACTION SYSTEM'
