Mercedes w124 88 sallon 3.0 fule not flowing
MERCEDES1988
london
mercedes w124 300e 1988
Well it has been a while now and my mercedes is not starting because the fuel is not flowing so i put in a new relay and it still did not start so i triggerd the relay and then it started but soon as i had let gone it stopped and it showes their is fuel in the car on the dials can someone please tell me what is wrong with my mercedes i have ran out off ideas can you please help me :(
thank you
You might have an ignition switch problem. check fuse 7 [16amp]is hot with the ignition on. Reseat the fuse as the contacts can getcorroded
it is not any thing to do with the ignition because when i turn the ignition on i do no hear the fule flowing and when i triggered the relay and turn the key it worked do you no anything about this or what it is please help me :(
What exactly do you mean by "triggered the relay" ? Do you mean you shorted out the main contacts or supplied12v to the actuating coil?
