Azmuf1
Hi guys,
I have a 2014, Cla which has started to make a metallic sound which is annoying as not sure what is causing it.
From what i can tell it occurs after i brake, go over a speed bump or accelerate from a slow speed & sometimes when i turn left.
I can only hear the sound at slow speeds and sounds like its coming from the rear of the car. (Drivers side)
The noise sounds like a metallic noise like something is loose but goes away straight away.
Apart from that the car drives spot on.
Any advice/info on what to check will be highly appreciated.
