Daveleckie10
Hi, I hope one of you experts can help me with this. Getting Misfires with Error codes on a 2015 E63 Tourer which the RAC cleared before the Mercedes dealer could diagnose them (RAC were acting as Mercedes recovery). Now in the position that I have to break down again before they can diagnose it!
I rejoined the ranks of E63 Tourer ownership on 15th April, purchasing a 2015 "Mercedes Approved" model with full dealership history and a 2 year, unlimited mileage AMG warranty (having owned a newer one before, I would not touch one without a dealership warranty). It was actually Car Magazine's long term test car and was in outstanding condition. It has 78K on the clock and is immaculate.
Yesterday I had the very unpleasant experience of the car developing a misfire, vibrating like a food mixer and going into "Limp" mode. I managed to get to a layby, switch it off / switch it back on and it ran normally. I called Mercedes recovery (the warranty includes 2 years of that) and the RAC duly turned up. The RAC technician did a reset of some sort, test drove it and said it was ok.
The car was already booked in to the local MB dealer today to get some pre-purchase issues sorted. Unfortunately, as the RAC tech had cleared the error codes, they had nothing to work with. Have any of you seen these error codes before and have any idea what could be the root cause (BTW, the MB dealer has been brilliant, offering to do extended road tests to try and recreate the issue)
Diagnostic Codes RAC DIAGNOSTIC SYSTEM
System Type: ENGINE
DTC: P0357,Ignition coil G , primary/secondary - circuit malfunction DTC: P0300,Random/multiple cylinder(s) - misfire detected
DTC: P0303,Cylinder 3 - misfire detected
DTC: P0302,Cylinder 2 - misfire detected
DTC: P0306,Cylinder 6 - misfire detected
System Type: ENGINE ELECTRONICS
Name: ENGINE ELECTRONICS
DTC: P0357,Ignition coil 7, electrical fault or open circuit
DTC: P0302,Cylinder 2 Misfire Detected
DTC: P0306,Cylinder 6 Misfire Detected
DTC: P0303,Cylinder 3 Misfire Detected
DTC: P0300,Random/multiple cylinder misfire in gasoline mode detected
System Type: GEARBOX - GEARBOX
Name: GEARBOX - GEARBOX
DTC: P0721,Gearbox output speed signal; coherance
System Type: PARKING ASSISTANCE - PARKING ASSISTANCE (PTS) Name: PARKING ASSISTANCE - PARKING ASSISTANCE (PTS)
DTC: U0168,CAN: fault message from EIS (Electronic Ignition System)
System Type: SIGNAL ACQUISITION AND CONTROL MODULE - FRONT (SAMF_212)
- SIGNAL ACQUISITION AND CONTROL MODULE - FRONT
Name: SIGNAL ACQUISITION AND CONTROL MODULE - FRONT - SIGNAL ACQUISITION AND CONTROL MODULE - FRONT (SAMF_212)
DTC: B181E,Sensor for the engine hood lifter DTC: B2379,Front wiper motor
System Type: ACTIVE BRAKE ASSIST - ACTIVE BRAKE ASSIST (FCW246) Name: ACTIVE BRAKE ASSIST - ACTIVE BRAKE ASSIST (FCW246)
DTC: C10C8,Warning from the control unit COLLISION PREVENTION ASSIST
System Type: ENGINE
