It likely means that you have water in the cabin, and if it happens regularly then you possibly have a leak. Check under the carpets for moisture, clean the drain holes (don’t forget the sunroof), check the seals around the doors and windows are not damaged or out of position, and change your cabin filter. Open the doors on warm days to help release the moisture as it evaporates.
