More clock problems?
Lovelycat
sk71bg
Vito 120, 250Sec, 280SEL3.5
Hi, i am new to this but have 2 problems- its a 639 vito cd120 with comand- the dashboard clock cannot be set as there are only year, month and day options but no minutes or seconds, and you cannot change the digital speed to miles from km- the clock reads correctly on the nav though-
I have tried disconnecting the battery etc to no avail- it is driving me nuts! also getting into the "settings" menu is nearly impossible and not as described in the manual or on any forum-
Thanks in advance?!
The dash clock should update from the Comand, and that updates automatically.
I'm guessing there is a comms problem between the 2.
I removed Comand so need change my clock using Star, as there is no function within the dash menus.
I did wonder about that, but i still have months/years/days in the settings etc and cannot change the km to miles?
IIRC the speed readout on the cluster is always kph on UK spec vans because the speedo dial only shows mph. You may be able to get it 'coded' to show mph but I'm pretty sure this isn't a cluster menu option.
Is the COMAND original or was it retrofitted? As mentioned it should feed the time to the cluster display.
Its all original, everything works fine but not having a clock drives me mad- i can put up with poorish performance and mpg despite 3 litres of jeep engine but even disconnecting the battery at 12 doesnt cut the mustard!
