John20
Hi guys,
I've had an MOT done and its failed on:
I'm pretty certain the garage just didn't put the handbrake on properly (which I've done too) because I've had this car on steeeeep hills and never found it doesn't hold the car... but I could be wrong! Assuming it does need work I've been quoted £550 for the above work, does that seem reasonable? any advice appreciated thanks
- Nearside Front Suspension arm ball joint dust cover no longer prevents the ingress of dirt rear (5.3.4 (b) (ii))
- Offside Front Suspension arm ball joint dust cover no longer prevents the ingress of dirt rear (5.3.4 (b) (ii))
- Parking brake efficiency below requirements (1.4.2 (a) (i)
