DaveMargetts
I have a v6 2.8 litre Japanese import Viano minivan that starts well, but as soon as I press the accelerator pedal, the engine stalls. If I wait for it to warm up, it seems to rev up quite normally but there's a distinct 'hunting' in the revs at idle and at any other rev range. I can't see any leaks in the vacuum hoses (that I can see). A local garage identified the Mass airflow unit as faulty and replaced it but according to them, it's still showing a MAFS fault and possibly a throttle body fault. I've cleaned out the throttle body and it looks OK to me. My diagnostic tool will unfortunately not connect with the van's computer, so I've not been able to interrogate the fault codes any further. Has anyone got any suggestions?
I should add that I've replaced all 6 spark plugs, the air filter and the fuel filter. I also hooked up a strobe to the HT leads and all 6 seem to be firing as they should.
