Hope all are well. Need some help to (hopefully) fix a small problem if there is every such a thing with Mercs!
My car is a 2003 S211 E220 CDI Estate (similar to W211 I think).
A Beemer zoomed past my parked car yesterday from the opposite direction and clipped the passenger door mirror from the front. The mirror shut itself but when I had a closer look, the glass on the indicator has been shattered and the actual mirror plate inside is hanging out as well now (held by 2 thin wires).
Questions:
1. The replacement clear indicator part number showing online is A2038201321. But I've a puddle lamp too which does not show up on the picture of new part. Would I be able to simply plug/ solder mine in with the new one?
2. I am unable to clip the mirror back? Don't see any broken plastic clips, so does this need to be glued at the back with the motor?
3. Can I somehow take the body painted case/ cover off with the indicator and replace the indicator? I am hoping this is possible otherwise I would need to remove the motor and associated wires to reach the inner side of mirror cover/ indicator.
Your help is highly appreciated. Thanks in advance..
Questions:
