John300SDTurbo
Hello,
A few months ago I aquired a 1983 300SD Turbo and I couldn't happier with the car. The car has over 350,000 miles on it, averages 34mpg plus, and runs like a dream. Recently I've had a quirk pop up that I can't quite figure out. At idle, in gear or out, the engine vibrates much more noticably than it did originally. As soon as I touch the pedal it smoothes right out and runs perfectly. I change the oil and all filters as recommended. Any and all sugestions or ideas would be appreciated.
While I'm here, how do you test a glowplug and where is the infamous glowplug control relay located and can it be be tested?
Thanks in advance for the help.
