mdelfunt
- Nov 15, 2016
- Location
- Georgia, USA
- 08 E320 Bluetek 200k miles, 06 e320 CDI, 290k miles.
Hey guys, been a while since I was here. Got a new problem on my 06 E320 CDI. It now has 313k miles. It's going into Limp mode and getting a P2047-1 "Rail pressure monitoring via volume control valve The rail pressure is too low". The car started this all of a sudden and left me in Limp mode on the side of the road. It will crank and runs good until you accelerate typically over 3k RPM's. Then it will kill the engine. At times, it will run but limit it to 3K RPM's. It has a NEW OEM fuel tank pump and OEM filter.
On my scanner, I've been watching fuel pressure along with the Quantity Control valve (Y74), and Pressure Regulator valve (Y94). Pressure starts out at around 480 bars at idle and moves up as I accelerate. I've seen it get as high as maybe 650 bar. When I get near 3k RPM's I can see the pressure start to trend downward until the engine dies. The Quantity Control valve and Pressure regulator valve appear to be doing something but I can tell what the root cause is since they all seem to fall off at the same time when the engine dies. I've read that the Quantity Control valve (Y74) and Pressure Regulator valve (Y94) are likely culprits but I don't want to start changing parts too early. I don't have a STAR to manipulate these two valves. I suppose it's also possible for the HPFP is bad or even leaky injectors. BTW, dealer wanted to change HPFP, Fuel Rail/Regulator, and Injectors to fix it.
How can I narrow this down to take the next steps?
I get conflicting information about whether the Pressure Regulator can be purchased separate from the Fuel rail. Is that true?
