Need help with Mercedes W124 260E Crankshaft Semsor- part number
optimusprime
Kidderminster Worcestershire UK
Mercedes W124 260E M103
Need a rear crankshaft sensor, just for spare , but unsure about the part number ...vin number is WDB1240262A941384 - 1989 to 1993 Engine is 122 - 166 M103 March 1989 .
Carat 3.6 where did you find it ..i came up with a few numbers starting with A021539228 .did you use the vin number i left ?
Took it directly from the part itself, I have two m103 powered cars in for work and at least 3 engines in the stores.
Carat but they are not M103 2.6 engines are they, more like M103 300e every part i looked at for my 260E is 0021 153 and not 002 159 can ypu have a think about it .. thanks for your help
One of the 2.6 engines has: 002 153 5628, the other has: 002 159 33 28. But the sensors are identical in every way, it's probably just one part number superseded the last.
What I can tell you is that the crank sensor from an m103 is also used on the early m104, late m117, and early m119. Doesn't matter about the engine capacity they are all the same.
I've got a 560 v8 waiting to go in a w124 which also has 002 153 5628 in it.
Hope that helps.
Carat well yes in a way its made the problem mor complicated now...i will do more checking with the number you gave me on web site . Thanks for staying with me, and i will come back once i find a match with your part numbers . My friend Rob on Ebay as a new one .And even he said to make sure the part number is the right one before i pay for it. And he sold hundreds of parts for mercs .
