New guy with blowby it kinda rhymes
Bushwagon
Portugal
Mercedes s124td 250d
Hi everyone.
I own a diesel s124 wagon with 650.000kms
I've done some serious work on it for the last 2 years, think I've had every single problem you could think of, this was a very tired car and it has come a long way ever since.
Recently I noticed something new..... I have some blowby, and this has really upset me as I have put some ridiculous man hours on this project so far.
Now I've read countless threads over different forums over this topic but I'm still confused.
I'll discribe my symptoms the best I can.
Upon start up with a cold engine i get blue smoke not massively but some, the injectors are new monarks.
With the engine cold if I open the oil filler cap the pressure rattles the cap, doesn't blow it across the yard but rattles. if i accelerate it creates vacuum instantaneously.
So far I had to replace all rubber bushings hoses etc as it was all pretty gone. I wonder before I assume the worst "rings" if this excess blowby could be caused by the valve stem seals? As they are made out of rubber too? This car had spent a great deal of time parked before I purchased it. Maybe that could help with their deterioration.
Any ideas or related experiences are welcome.
Many thanks
Hi everyone and happy new year to all.
Just a quick update my problems are fixed, my heavy nailing was in fact an injector even tho I've changed the nozzles somehow the fourth one was not happy, the way i discovered this was pretty simple, the actual metal fuel line was reciving part of the impact everytime it nailed, so upon comparison with the other lines this one was pretty heavy you could feel it just by touch.
I've simply replaced the housing inc spring etc and fitted my monark nozzle into it and voila.
My smoke is gone too as a result from the injector I believe, the blowby I've fixed it too simply done an engine flush, mixed a litre of atf with the oil drove it for a couple days, then just used a valvoline engine flush thingy and that was it......
No more smoke no noise no nothing in fact it runs smoother than ever.
Hope this helps someone out there.
650,000 kms :eek:
1.3 million kms :eek::eek::eek:
