Hello,
Car is a 2012 220CDi coupe, OM651 engine.
It was going into limp mode with P0122 and live data showed throttle stuck at 99.4%
There was no movement from the throttle flap at any time, wiring plug (when unplugged) was giving 5v on pins 1 & 4, Pin 5 at 0v.
So I put a new Bosch throttle body in, turned ignition to pos 2 and throttle flap goes back and forth a few times (live data reflects this) and returns by spring to its fully open position. Live data shows this as being 88.64%.
Starts up OK but throws up error P2112 which appears to be saying that the actuator is stuck when clearly the car knows it moves on startup.
Does it need the ECU updated with the standard resistance values from the new throttle? and if so is this a Star only thing or is there a DIY level scan tool which can do this?
Thanks for reading.
Gordon.
Thanks for reading.
Gordon.
